[GRASS-dev] problem in detecting the projection information from the raster layers when using the batch import
Markus Neteler neteler at osgeo.org
Sat Jun 25 16:25:19 PDT 2016
On Fri, Jun 24, 2016 at 2:26 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> I want to import raster layers from
> https://www.york.ac.uk/environment/research/kite/resources/ (latlon/WGS84)
> into a location/mapset (also latlon/WGS84). This is no problem when
> importing one by one (Source type = File), but when I try to import all
> raster layers in a directory (Source type = Directory), I am getting the
> message that "Projection of following layers do not match with projection of
> current location" (listing all layersin the directory). So there seems to be
> a problem in detecting the projection information from the raster layers
> when using the batch import.
Do all of them come with the *identical* projection string?
Markus
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
