[GRASS-dev] Addons: Python error when checking if package is installed - r.randomforest
Markus Neteler
neteler at osgeo.org
Mon Jun 27 04:18:06 PDT 2016
I was checking why r.randomforest is not showing up on the Web site:
The log file gives an error here:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.randomforest/r.randomforest.py#L158
grass.fatal("Python package <%s> not installed
(python-sklearn). Exiting" % module_name)
but the sklearn package *is* installed.
Trying it manually on the server:
neteler at osgeo6:~$ python
Python 2.7.9 (default, Mar 1 2015, 12:57:24)
>>> import atexit, random, string, imp, re
>>> imp.find_module("sklearn")
(None, '/usr/lib/python2.7/dist-packages/sklearn', ('', '', 5))
... how come?
Checking if it is really installed:
neteler at osgeo6:~$ ls /usr/lib/python2.7/dist-packages/
antlr.py lxml/ Pyste/
defusedxml-0.4.1.egg-info PIL/ six.pyc
dns/ PILcompat/ sklearn/
--> installed.
neteler at osgeo6:~$ ls /usr/lib/python2.7/dist-packages/sklearn/
base.py feature_extraction/ lda.pyc qda.py
base.pyc feature_selection/ linear_model/ qda.pyc
What's wrong on the server? Or is the test wrong?
(I noted that various GRASS scripts use different ways for this check,
the test for 3rd party packages should be standardized.)
Thanks for any hints.
Markus
