[GRASS-dev] r.cross categories for combinations with all 0 (zero)
Paulo van Breugel p.vanbreugel at gmail.com
Mon Jun 27 05:18:28 PDT 2016
On 27-06-16 13:16, Paulo van Breugel wrote:
> Dear all,
> In r.cross if all input layers have 0 (zero), the resulting layer
> get's assigned the category 0, but no label is assigned (even if in
> the input maps the category 0 have a label). Is there any specific
> reason for that?
In fact, if two layers have value 1, the resulting category is 0, and no
label is assigned. For example, the category 0 in the category report
below are the areas where both input maps A and B have value 1 and label
'non-forest'. So in my understanding it should have the label
'non-forest; non-forest' (and shouldn't it have category value '1'?
|MASK: MASK in JP_working                                                     |
|MAP: Cross of A and B (Comp_fc at JP_working in JP_working)                     |
|             Category Information               |           |     cell|   %  |
|#|description                                   |   hectares|    count| cover|
|0| . . . . . . . . . . . . . . . . . . . . . . .| 62,491,815| 73165335| 44.10|
|1|non-forest; forest . . . . . . . . . . . . . .|  3,233,291|  3783472|  2.28|
|2|forest; non-forest . . . . . . . . . . . . . .|  5,956,016|  6968998|  4.20|
|3|forest; forest . . . . . . . . . . . . . . . .|  3,497,042|  4091703|  2.47|
|4|forest_M; non-forest . . . . . . . . . . . . .|  1,938,309|  2270237|  1.37|
|5|forest_M; forest . . . . . . . . . . . . . . .|    193,497|   226765|  0.14|
|*|no data. . . . . . . . . . . . . . . . . . . .| 64,406,159| 75462231| 45.45|
|TOTAL                                           |141,716,130|165968741|100.00|
> Rgds,
> Paulo
