[GRASS-dev] [GRASS GIS] #3085: Batch import with import raster data tool does not recognize projection information
trac at osgeo.org
Wed Jun 29 12:28:49 PDT 2016
information
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
What exactly is the issue, here ?
I get the exact same window be it with one file or with a directory. It is
just an additional step to make you conscious about the fact that the
module will proceed with reprojecting the files. Just select the files you
are sure you want to import with reprojection and then proceed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3085#comment:1>
