[GRASS-dev] [GRASS GIS] #2936: v.net.distance: wrong directions in one-way streets
trac at osgeo.org
Thu Mar 3 13:06:21 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.net.distance network one-way
CPU: | direction
Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:4 mlennert]:
> Replying to [comment:3 mmetz]:
> I don't have a problem with line directions remaining as in the
original.
I have, so I adjusted line directions to match path directions in r67990.
v.net.path also adjusts line directions to match path directions.
> >Correct paths are created with trunk r67984,5.
> Thanks, works great now !
> > There is also a new -l flag that produces a single line for each path
with appropriate line direction.
> Nice. Just one remark: the line seems to only have a category value in
layer 2, not in layer 1. Is that intended ?
Not really intended, paths got all categories of their from feature.
Changed in r67990 to match the default output of paths consisting of
different lines. I got distracted by the directed graph library which is
only slightly less difficult to read than the wxpython GUI code base.
AFAICT, v.net.distance is now the only module using version 2 directed
graphs. All other v.net.* modules use version 1 directed graphs. The
directed graph library offers to create graphs (networks) of version 1, 2,
and 3. Only version 1 graphs have been used and tested since 2003 within
GRASS GIS.
I have introduced this bug indirectly myself by adding options to define
different forward and backward costs to lines, without updating the
underlying code base (GSoC project 2009 by Daniel Bundala, impressive code
quality and thorough understanding of network analysis).
It is not clear to me why v.net.distance copies 'from' features to the
output but not 'to' features. Any opinion?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2936#comment:5>
