[GRASS-dev] [GRASS-SVN] r68077 - in grass/branches/releasebranch_7_0/scripts: r.blend r.rgb
Vaclav Petras
wenzeslaus at gmail.com
Fri Mar 18 08:19:07 PDT 2016
Markus, all,
On Fri, Mar 18, 2016 at 10:09 AM, <svn_grass at osgeo.org> wrote:
> Author: neteler
> Date: 2016-03-18 07:09:42 -0700 (Fri, 18 Mar 2016)
> New Revision: 68077
> r.rgb: more keywords; fix example; r.blend manual: add r.rgb reference
> (trunk, r68076)
> <div class="code"><pre>
> g.region raster=elevation -p
> -r.rgb input=elevation
> +r.rgb input=elevation red=elevation.r green=elevation.g blue=elevation.b
> </pre></div>
I know we have dot in map names in lot of places but I though we want to
advertise underscore now because it works with vectors and database tables
(as well as columns).
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160318/07b174ed/attachment.html>
