[GRASS-dev] [GRASS-SVN] r68077 - in grass/branches/releasebranch_7_0/scripts: r.blend r.rgb
Fri Mar 18 10:00:42 PDT 2016
Vaclav Petras wrote:
> I know we have dot in map names in lot of places but I though we want to
> advertise underscore now because it works with vectors and database tables
> (as well as columns).
Maybe if people keep using a dot, someone will eventually care enough
about the broken 5.3 vector changes to fix the issue, rather than
expecting everyone else to work around it.
