[GRASS-dev] raster query/r.what error with a r.external-linked raster
Helmut Kudrnovsky
hellik at web.de
Tue Mar 22 07:03:09 PDT 2016
wenzeslaus wrote
> On Mon, Mar 14, 2016 at 4:02 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> Module run None ['r.what', '--q', '-rf',
>> 'map=EUD_CP_DEMS_3500025000_AA at demdata', 'null=No data',
>> 'coordinates=3532112.092810,2247474.190841'] ended with
>> error
>> Process ended with non-zero return code -11. See errors in
>> the (error) output.
> Can you run this with gdb (you need to compile with -ggdb)?
>> gdb r.what
> (gdb) run -rf map=EUD_CP_DEMS_3500025000_AA at demdata
> [it should segfault now]
> (gdb) bt
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
as I'm not used to compile on Linux, what may be the command to
compile with -ggdb? configure? make?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/raster-query-r-what-error-with-a-r-external-linked-raster-tp5256308p5257823.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
