[GRASS-dev] raster query/r.what error with a r.external-linked raster
Vaclav Petras
wenzeslaus at gmail.com
Tue Mar 22 18:24:07 PDT 2016
On Tue, Mar 22, 2016 at 10:03 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> as I'm not used to compile on Linux, what may be the command to
> compile with -ggdb? configure? make?
It is a compiler flag and it can be set using before you run ./configure
using the CFLAGS environmental variable, so e.g.
export CFLAGS="-ggdb -Wall"
./configure ...
see full examples here
https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160322/ddf33a37/attachment.html>
