[GRASS-dev] r.rgb: syntax error, unexpected $end, expecting VARNAME or NAME or STRING
Markus Metz
markus.metz.giswork at gmail.com
Tue Mar 22 14:37:20 PDT 2016
On Fri, Mar 18, 2016 at 3:10 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Mar 16, 2016 at 9:24 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Wed, Mar 16, 2016 at 1:27 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> I just needed r.rgb and found the script broken: must be a silly bug
>>> but I don't see it..:
>>> # NC
>>> GRASS 7.1.svn (nc_spm_08_grass7): > r.rgb input=elevation
>>> Parse error
>>> ERROR: parse error
>>> ERROR: An error occurred while running r.mapcalc
>>> Any idea?
Is there any reason why this should not work? According to the manual
it should work.
If neither red or green or blue are given, r.rgb could use
red=${input}.r
green=${input}.g
blue=${input}.b
That would be easy to fix.
Markus M
>> Not all options are required but at least one of them:
>> https://trac.osgeo.org/grass/changeset/68072
> I see, that now works:
> Description:
> Splits a raster map into red, green and blue maps.
> Keywords:
> ERROR: At least one of the following options is required: <red>,
> <green> and <blue>
> ok. But another error occurs (missing error handling if the output
> names were selected to be identica):
> red=elevation green=elevation blue=elevation
> syntax error, unexpected '=', expecting '('
> Parse error
> ERROR: parse error
> Eventually this works:
> r.rgb input=elevation red=elevation.r green=elevation.g blue=elevation.b
> Perhaps there is an elegant solution to catch the (user) error above?
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
