[GRASS-dev] r.rgb: syntax error, unexpected $end, expecting VARNAME or NAME or STRING
Vaclav Petras
wenzeslaus at gmail.com
Tue Mar 22 16:32:44 PDT 2016
On Tue, Mar 22, 2016 at 5:37 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> Is there any reason why this should not work? According to the manual
> it should work.
> If neither red or green or blue are given, r.rgb could use
> red=${input}.r
> green=${input}.g
> blue=${input}.b
> That would be easy to fix.
I thought we tried to remove this type of default parameters from most of
the modules (with the exception of import/export). Perhaps not.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160322/30a5ba85/attachment.html>
