[GRASS-dev] GRASS 7.0.3 for El Capitan without disabling SIP!
Rainer M Krug Rainer at krugs.de
Wed Mar 23 04:06:52 PDT 2016
Hi
I just received the news, that the new homebrew recipe for GRASS 7.0
does install on El Capitan with SIP enabled!
This is thanks to Larry Shaffer.
See
https://github.com/OSGeo/homebrew-osgeo4mac/issues/118#issuecomment-200278686
The recipe is part of the Homebrew-osgeo4mac tap, see
for info on how to use them.
I will see that I can port the changes to my grass-71 formula as well -
will keep you posted when it works.
Thanks a lot Larry,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160323/79997bbb/attachment.sig>
