[GRASS-dev] r.regression.multi failing
Paulo van Breugel p.vanbreugel at gmail.com
Wed Mar 23 06:31:34 PDT 2016
I am using r.regression.multi in a python script (using
grass.run_command()) to compute the variance inflation factor (VIF).  It
runs in a loop, regressing variables one by one to all the other
variables. It sometimes happen that the function fails with:
WARNING: Matrix is unsolvable
ERROR: Multiple regression failed
This causes my script to stop. However, I would like to capture this
warning / error, and continue. Do you know how I can accomplish this?
Paulo
