[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
GRASS GIS trac at osgeo.org
Fri Mar 25 01:27:29 PDT 2016
  Reporter:  martinl             |      Owner:  grass-dev@…
      Type:  task                |     Status:  new
  Priority:  blocker             |  Milestone:  7.1.0
 Component:  Projections/Datums  |    Version:  svn-releasebranch70
Resolution:                      |   Keywords:  gdal
       CPU:  Unspecified         |   Platform:  Unspecified
Comment (by neteler):
 The current state of relbranch70 is:
 GRASS 7.0.4svn (latlong):> g.proj epsg=5514 -w
 PROJCS["S-JTSK / Krovak East North",
     GEOGCS["bessel",
         DATUM["Militar_Geographische_Institut",
             SPHEROID["Bessel_1841",6377397.155,299.1528128]],
         PRIMEM["Ferro",-17.666666666668],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Krovak"],
     PARAMETER["latitude_of_center",49.5],
     PARAMETER["longitude_of_center",42.5],
     PARAMETER["azimuth",0],
     PARAMETER["pseudo_standard_parallel_1",0],
     PARAMETER["scale_factor",0.9999],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
 # ==> wrong.
 When (locally) backporting the CSV fix r68128 I finally obtain the right
 relations between projection and datum:
 GRASS 7.0.4svn (latlong):> g.proj epsg=5514 datumtrans=-1 -t -w
 1
 Used in whole S_JTSK region
 towgs84=589.000,76.000,480.000
 Default 3-Parameter Transformation (May not be optimum for older datums;
 use this only if no more appropriate options are available.)
 2
 Used in Czech Republic
 towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
 Accuracy about 1m
 3
 towgs84=572.213,85.334,461.94,-4.9732,-1.529,-5.2484,3.5378
 Accuracy about 1m
 4
 Used in Slovakia
 towgs84=485,169.5,483.8,7.786,4.398,4.103,0
 Accuracy about 1m
 # selecting the 3rd datum:
 GRASS 7.0.4svn (latlong):> g.proj epsg=5514 datumtrans=3 -t -w
     GEOGCS["bessel",
         DATUM["System_Jednotne_Trigonometricke_Site_Katastralni",
             SPHEROID["Bessel_1841",6377397.155,299.1528128],
             TOWGS84[589,76,480,0,0,0,0]],
         PRIMEM["Greenwich",0],
     PARAMETER["longitude_of_center",24.83333333333333],
     UNIT["Meter",1]]
 # ==> better (Greenwich, not Ferro) but azimuth and
 pseudo_standard_parallel_1 seem to be wrong.
 See also: http://epsg.io/5514
 Any ideas?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2456#comment:14>
