[GRASS-dev] [GRASS GIS] #2845: Build failure with 7.0.3RC1 on Linux
trac at osgeo.org
Fri Mar 25 06:50:27 PDT 2016
Reporter: scimmia | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.0.4
Component: Compiling | Version: unspecified
Resolution: fixed | Keywords: xml, toolboxes, Makefile, svnprop,
| wxGUI, releasing
CPU: x86-64 | Platform: Linux
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:17 neteler]:
> Replying to [comment:16 scimmia]:
> > OK, new info. I was able to build from r67442 just fine. I ran a
recursive diff to see what the difference was between the tarball and the
svn checkout, and found that gui/wxpython/xml/menudata.xml and
gui/wxpython/xml/module_tree_menudata.xml don't exist in SVN. Removing
those files from the tarball lets me build.
> I have updated the release procedure to explicitly delete these files in
r67511, r67512.
> Now this should no longer happen.
Original issue solved for trunk and 7.0 branch. I'm closing the ticket.
Change of build system as suggested by [comment:32 Glynn] is for a
separate ticket (those who know how to formulate the problem, feel free to
open it).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2845#comment:33>
