[GRASS-dev] [GRASS GIS] #2970: Replace Vect_point_in_box() by Vect_point_in_box_2d() where appropriate
trac at osgeo.org
Fri Mar 25 07:27:30 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: new
Priority: minor | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: vlib, bbox, box | CPU: Unspecified
Platform: Unspecified |
In r66459 I have added `Vect_point_in_box_2d()` function which is simply a
2D version of `Vect_point_in_box()` function which is 3D only. The
motivation was #2734 and [https://lists.osgeo.org/pipermail/grass-
user/2015-July/072809.html an issue reported on mailing list]. I used the
new `Vect_point_in_box_2d()` to fix ''v.distance'' in r66460.
`Vect_point_in_box()` function is used a lot in the modules and very often
with hardcoded `0.0` as ''z'' parameter (and there might be also cases
when ''z'' is optionally zero). These should be replaced by the new 2D
only version of the function.
An alternative would be to add one function which would optionally
consider ''z'' using boolean ''has_z/is_2d'' or pointer for ''z'' and use
this function in the modules.
Currently it is not know if this is causing any issues as in case of
''v.distance''. Setting type to task and priority to minor.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2970>
