[GRASS-dev] [GRASS GIS] #2636: v.buffer, allow selection of columns for opts "distance", "minordistance", and "angle"
trac at osgeo.org
Fri Mar 25 15:40:53 PDT 2016
and "angle"
Reporter: isaacullah | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-releasebranch70
Resolution: | Keywords: v.buffer, columns
CPU: x86-64 | Platform: Linux
Comment (by martinl):
Replying to [comment:5 mmetz]:
> Replying to [ticket:2636 isaacullah]:
> The options "minordistance" and "angle" apply only to the GRASS-internal
buffering method which never worked. It is recommended to use only the
GEOS buffering method, but it does not support these options to create
oblong buffers. To avoid confusion, the options "minordistance" and
"angle" should be removed.
Agreed, are you planning to remove these options? Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/2636#comment:6>
