[GRASS-dev] [GRASS GIS] #2967: [PATCH] Super quiet mode
    trac at osgeo.org
    Sat Mar 26 11:44:59 PDT 2016
  Reporter:  rouault      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Parser       |    Version:  svn-trunk
Resolution:               |   Keywords:  patch
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by glynn):
 Replying to [ticket:2967 rouault]:
 > The attached proposed patch adds a --qq option for a super verbose mode
 that suppress everything but fatal warnings.
 The grass.script Python module will need an additional parameter on
 several functions (e.g. make_command() and anything which uses it).
 But then it's getting to the point where those options should probably be
 replaced with a single verbosity= option (and just set GRASS_VERBOSE
 directly rather than using switches).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2967#comment:5>
