[GRASS-dev] raster query/r.what error with a r.external-linked raster
Helmut Kudrnovsky hellik at web.de
Sat Mar 26 14:03:13 PDT 2016
>This may be an issue with GDAL itself, e.g. an external library having
>been updated without rebuilding GDAL. If that's the case, any program
>which calls GDALAllRegister() (e.g. "gdalinfo --formats") would
>exhibit the same issue.
gdalinfo testraster.tif
gdalinfo --formats
both are working.
>Alternatively, it may be an issue with GDAL and GRASS using different
>versions of a common library (e.g. libstdc++). If you've updated any
>system libraries, perform a full re-compile of GRASS (after "make
>clean") and
the debian installation is updated; several times svn up in grass and
recompiled, same behaviour.
>and ensure that GRASS isn't built against a "private" version
>of any system library used by GDAL.
how could this be tested/investigated? (linux newbie here on my side)
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/raster-query-r-what-error-with-a-r-external-linked-raster-tp5256308p5258490.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
