[GRASS-dev] raster query/r.what error with a	r.external-linked	raster
    Helmut Kudrnovsky
    hellik at web.de
    Mon Mar 28 11:04:12 PDT 2016
Helmut Kudrnovsky wrote
>>This may be an issue with GDAL itself, e.g. an external library having
>>been updated without rebuilding GDAL. If that's the case, any program
>>which calls GDALAllRegister() (e.g. "gdalinfo --formats") would
>>exhibit the same issue.
> gdalinfo testraster.tif
> gdalinfo --formats
> both are working.
>>Alternatively, it may be an issue with GDAL and GRASS using different
>>versions of a common library (e.g. libstdc++). If you've updated any
>>system libraries, perform a full re-compile of GRASS (after "make
>>clean") and
> the debian installation is updated; several times svn up in grass and
> recompiled, same behaviour.
>>and ensure that GRASS isn't built against a "private" version
>>of any system library used by GDAL.
> how could this be tested/investigated? (linux newbie here on my side)
found it. GDAL 2.0.2 is self compiled, Debian's Saga GIS is compiled
against Debian's GDAL 1.11.x.
Deinstalling Saga GIS, querying a linked raster in GRASS GIS works again.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/raster-query-r-what-error-with-a-r-external-linked-raster-tp5256308p5258590.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
