[GRASS-dev] .g.proj datum_trans (5514)
Markus Neteler
neteler at osgeo.org
Tue Mar 29 03:48:18 PDT 2016
On Sat, Mar 26, 2016 at 9:26 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> I tested recently committed changes regarding S-JTSK. I discovered
> strange behaviour of g.proj:
> 1) list transformation parameters
> g.proj epsg=5514 datum_trans=-1
> ERROR: No output format specified, define one of flags -p, -g, -j, or -w
> I needed to specify -t flag:
> .proj epsg=5514 datum_trans=-1 -t
> 1
> Used in whole S_JTSK region
> towgs84=589.000,76.000,480.000
> Default 3-Parameter Transformation (May not be optimum for older
> datums; use this only if no more appropriate options are available.)
Yes, this is a know and old issue. The -t flag should not be needed to
be specified since
" datum_trans=index
Index number of datum transform parameters "0" for unspecified or
"-1" to list and exit
> Moreover in GRASS 7.0 I DO NOT need to specify -t flag. Why this
> change happen in trunk? At least it's not documented in the parameter
> description.
I guess it is simply a bug.
> 2) specify transformation parameters
> g.proj epsg=5514 datum_trans=2 -p
> -PROJ_INFO-------------------------------------------------
> name : S-JTSK / Krovak East North
> towgs84 : 589,76,480,0,0,0,0
> Still uses first transformation option even I asked for second.
ouch
> Is there anything I am doing wrong or it's a bug? Thanks, Martin
This part is still buggy.
See also
https://trac.osgeo.org/grass/ticket/2456
Markus
