[GRASS-dev] [GRASS GIS] #2973: i.pansharpen - python UnicodeEncodeError
GRASS GIS trac at osgeo.org
Wed Mar 30 23:49:10 PDT 2016
 Reporter:  alf      |      Owner:  grass-dev@…
     Type:  defect   |     Status:  new
 Priority:  normal   |  Milestone:  7.0.4
Component:  Imagery  |    Version:  7.0.3
 Keywords:           |        CPU:  Unspecified
 Platform:  Linux    |
 unicode encode error arose from i.pansharpen. It exits with error both
 from gui and cli.
 Assigning grey equalized color tables to output images...
   File "/usr/lib/grass70/scripts/i.pansharpen", line 452, in <module>
     main()
   File "/usr/lib/grass70/scripts/i.pansharpen", line 319, in main
     flags="e", col='grey')
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 394, in
 run_command
     return handle_errors(returncode, returncode, args, kwargs)
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 312, in
 handle_errors
     returncode=returncode)
   File "/usr/lib/grass70/etc/python/grass/exceptions/__init__.py", line
 68, in __init__
     msg = _("Module run %s %s ended with error") % (module, code)
   File "/usr/lib/python2.7/gettext.py", line 369, in lgettext
     return tmsg.encode(locale.getpreferredencoding())
 UnicodeEncodeError: 'ascii' codec can't encode character u'\xe8' in
 position 30: ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2973>
