[GRASS-dev] [GRASS GIS] #2973: i.pansharpen - python UnicodeEncodeError
GRASS GIS trac at osgeo.org
Wed Mar 30 23:52:19 PDT 2016
  Reporter:  alf          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.4
 Component:  Imagery      |    Version:  7.0.3
Resolution:               |   Keywords:  i.pansharpen
       CPU:  Unspecified  |   Platform:  Linux
Changes (by martinl):
 * keywords:   => i.pansharpen
Old description:
> Hi,
> unicode encode error arose from i.pansharpen. It exits with error both
> from gui and cli.
> Assigning grey equalized color tables to output images...
> Traceback (most recent call last):
>   File "/usr/lib/grass70/scripts/i.pansharpen", line 452, in <module>
>     main()
>   File "/usr/lib/grass70/scripts/i.pansharpen", line 319, in main
>     flags="e", col='grey')
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 394, in
> run_command
>     return handle_errors(returncode, returncode, args, kwargs)
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 312, in
> handle_errors
>     returncode=returncode)
>   File "/usr/lib/grass70/etc/python/grass/exceptions/__init__.py", line
> 68, in __init__
>     msg = _("Module run %s %s ended with error") % (module, code)
>   File "/usr/lib/python2.7/gettext.py", line 369, in lgettext
>     return tmsg.encode(locale.getpreferredencoding())
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xe8' in
> position 30: ordinal not in range(128)
New description:
 from gui and cli.
     main()
 run_command
 handle_errors
 68, in __init__
Ticket URL: <https://trac.osgeo.org/grass/ticket/2973#comment:1>
