[GRASS-dev] IAU to wkt C code (converted from Trent Hare's Python code)
Markus Neteler
neteler at osgeo.org
Thu May 5 10:56:41 PDT 2016
Hi Yann,
back to this topic:
On Tue, Feb 23, 2016 at 5:26 PM, Yann <yann.chemin at gmail.com> wrote:
> I have converted the Python script
> from Trent Hare to generate on the fly PROJCS and GEOCS WKTdescriptions for
> all IAU2000 and IAU2009.
> PS: GDAL is also going to insert it.
Did this actually happen?
Because GRASS no longer reads local CSV files and - to my knowledge -
completely relies on GDAL/PROJ (see https://trac.osgeo.org/grass/ticket/2456).
Hence, your two CSV files iau2000.csv + iau2009.csv and no longer shipped.
Can you confirm that all works fine through GDAL (which version is
needed to have IAU support?)
thanks
Markus
