[GRASS-dev] IAU to wkt C code (converted from Trent Hare's Python code)
Yann Chemin yann.chemin at gmail.com
Thu May 5 22:58:20 PDT 2016
Checking with Trent, will report here soon.
On May 5, 2016 7:57 PM, "Markus Neteler" <neteler at osgeo.org> wrote:
> Hi Yann,
> back to this topic:
> On Tue, Feb 23, 2016 at 5:26 PM, Yann <yann.chemin at gmail.com> wrote:
> > I have converted the Python script
> > from Trent Hare to generate on the fly PROJCS and GEOCS WKTdescriptions
> for
> > all IAU2000 and IAU2009.
> > PS: GDAL is also going to insert it.
> Did this actually happen?
> Because GRASS no longer reads local CSV files and - to my knowledge -
> completely relies on GDAL/PROJ (see
> https://trac.osgeo.org/grass/ticket/2456).
> Hence, your two CSV files iau2000.csv + iau2009.csv and no longer shipped.
> Can you confirm that all works fine through GDAL (which version is
> needed to have IAU support?)
> thanks
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160506/263d0a56/attachment.html>
