[GRASS-dev] IAU to wkt C code (converted from Trent Hare's Python code)
Yann yann.chemin at gmail.com
Fri May 6 11:01:10 PDT 2016
OK had a time to look at
https://trac.osgeo.org/grass/ticket/2456
Removing the WKT files iau2000.csv & iau2009.csv will stop the wizard
new location based on these IAU files to work. These files are not in
GDAL yet and they are parsed by the New Location wizard on selection of
the IAU-based option. Getting those files in GDAL is rather an issue as
yet, I might have time to do that in the near future (i.e. coming
months), but not in the coming weeks. Please could you restore those
files. Thank you, Yann
On 06/05/2016 06:58, Yann Chemin wrote:
> Checking with Trent, will report here soon.
> On May 5, 2016 7:57 PM, "Markus Neteler" <neteler at osgeo.org> wrote:
>> Hi Yann,
>> back to this topic:
>> On Tue, Feb 23, 2016 at 5:26 PM, Yann <yann.chemin at gmail.com> wrote:
>>> I have converted the Python script
>>> from Trent Hare to generate on the fly PROJCS and GEOCS WKTdescriptions
>> for
>>> all IAU2000 and IAU2009.
>>> PS: GDAL is also going to insert it.
>> Did this actually happen?
>> Because GRASS no longer reads local CSV files and - to my knowledge -
>> completely relies on GDAL/PROJ (see
>> https://trac.osgeo.org/grass/ticket/2456).
>> Hence, your two CSV files iau2000.csv + iau2009.csv and no longer shipped.
>> Can you confirm that all works fine through GDAL (which version is
>> needed to have IAU support?)
>> thanks
>> Markus
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
