[GRASS-dev] [GRASS GIS] #3011: OSGeo4W-winGRASS71 r68376: starting wxgui fails
GRASS GIS trac at osgeo.org
Thu May 5 12:35:34 PDT 2016
 Reporter:  hellik       |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  critical     |  Milestone:  7.0.5
Component:  wxGUI        |    Version:  svn-trunk
 Keywords:               |        CPU:  x86-64
 Platform:  MSWindows 7  |
 error message:
 Cleaning up temporary files...
 Starting GRASS GIS...
   File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\gis_set.py",
 line 1200
 , in <module>
     GRASSStartUp = StartUp(0)
   File "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-
 unicode\wx\_core.
 py", line 7981, in __init__
     self._BootstrapApp()
 unicode\wx\_core.
 py", line 7555, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
 line 1175
 , in OnInit
     StartUp = GRASSStartup()
 line 230,
  in __init__
     self._set_properties(grassVersion, grassRevisionStr)
 line 282,
  in _set_properties
     self.OnSetDatabase(None)
 line 929,
  in OnSetDatabase
     self.UpdateLocations(self.gisdbase)
 line 796,
  in UpdateLocations
     self.lblocations.InsertItems(self.listOfLocations, 0)
 line 1152
 , in InsertItems
     self._LoadData(choices, disabled)
 line 1141
 , in _LoadData
     index = self.InsertStringItem(sys.maxsize, item)
 unicode\wx\_contr
 ols.py", line 4761, in InsertStringItem
     return _controls_.ListCtrl_InsertStringItem(*args, **kwargs)
 wx._core.PyAssertionError: C++ assertion "m_count ==
 ListView_GetItemCount(GetHw
 nd())" failed at ..\..\src\msw\listctrl.cpp(1629) in
 wxListCtrl::InsertItem(): m
 _count should match ListView_GetItemCount
 ERROR: Error in GUI startup. See messages above (if any) and if necessary,
 pleas
 e report this error to the GRASS developers.
 On systems with package manager, make sure you have the right GUI package,
 proba
 bly named grass-gui, installed.
 To run GRASS GIS in text mode use the -text flag.
 Exiting...
 Drücken Sie eine beliebige Taste . . .
Ticket URL: <https://trac.osgeo.org/grass/ticket/3011>
