[GRASS-dev] [GRASS GIS] #3011: OSGeo4W-winGRASS71 r68376: starting wxgui fails
trac at osgeo.org
Fri May 6 04:42:29 PDT 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.5
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [ticket:3011 hellik]:
> error message:
> Cleaning up temporary files...
> Starting GRASS GIS...
> Traceback (most recent call last):
> File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\gis_set.py",
line 1200
> , in <module>
> GRASSStartUp = StartUp(0)
> File "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-
unicode\wx\_core.
> py", line 7981, in __init__
> self._BootstrapApp()
unicode\wx\_core.
> py", line 7555, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 1175
> , in OnInit
> StartUp = GRASSStartup()
line 230,
> in __init__
> self._set_properties(grassVersion, grassRevisionStr)
line 282,
> in _set_properties
> self.OnSetDatabase(None)
line 929,
> in OnSetDatabase
> self.UpdateLocations(self.gisdbase)
line 796,
> in UpdateLocations
> self.lblocations.InsertItems(self.listOfLocations, 0)
line 1152
> , in InsertItems
> self._LoadData(choices, disabled)
line 1141
> , in _LoadData
> index = self.InsertStringItem(sys.maxsize, item)
unicode\wx\_contr
> ols.py", line 4761, in InsertStringItem
> return _controls_.ListCtrl_InsertStringItem(*args, **kwargs)
> wx._core.PyAssertionError: C++ assertion "m_count ==
ListView_GetItemCount(GetHw
> nd())" failed at ..\..\src\msw\listctrl.cpp(1629) in
wxListCtrl::InsertItem(): m
> _count should match ListView_GetItemCount
> ERROR: Error in GUI startup. See messages above (if any) and if
necessary, pleas
> e report this error to the GRASS developers.
> On systems with package manager, make sure you have the right GUI
package, proba
> bly named grass-gui, installed.
> To run GRASS GIS in text mode use the -text flag.
> Exiting...
> Drücken Sie eine beliebige Taste . . .
Tested with osgeo4w winGRASS 7.1svn from today, still an issue
Ticket URL: <https://trac.osgeo.org/grass/ticket/3011#comment:1>
