[GRASS-dev] [GRASS GIS] #3007: pygrass.messages.Messenger.percent() smallest step is 2
GRASS GIS trac at osgeo.org
Thu May 5 22:08:34 PDT 2016
  Reporter:  lrntct  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.2.0
 Component:  LibGIS  |    Version:  svn-trunk
Resolution:          |   Keywords:
       CPU:  x86-64  |   Platform:  Linux
Changes (by zarch):
 * component:  PyGRASS => LibGIS
Comment:
 I change the component fom pygrass to LibGis since I see the problem also
 with C code:
 #include<unistd.h>
 #include <grass/gis.h>
 int main()
         int row;
         int nrows = 1352;
         G_message("Percent complete...");
         for (row = 0; row < nrows; row++)
                 G_percent(row, nrows, 1);
                 usleep(10000);
         G_percent(1, 1, 1);
         return 0;
 Looking at the `G_percent` code I don't understand when is used the
 function `G_set_percent_routine(int (*percent_routine) (int))` within the
 GRASS code and where the default percent_routine is defined.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3007#comment:2>
