[GRASS-dev] [GRASS GIS] #2494: d.vect.thematic broken
trac at osgeo.org
Fri May 6 06:20:57 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-releasebranch70
Resolution: | Keywords: d.vect.thematic, d.graph
CPU: Unspecified | Platform: Linux
Comment (by lazaa):
From the documentation it seems that currently the module d.vect.thematic
works only for polygons (type=area data). For point data there is a module
in AddOns d.vect.thematic2. I tried run the module d.vect.thematic2 with a
sample of points and everything worked well with no error.
Adam
Ticket URL: <https://trac.osgeo.org/grass/ticket/2494#comment:2>
