[GRASS-dev] [GRASS GIS] #2494: d.vect.thematic broken
GRASS GIS trac at osgeo.org
Fri May 6 08:00:30 PDT 2016
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.5
 Component:  Display      |    Version:  svn-releasebranch70
Resolution:               |   Keywords:  d.vect.thematic, d.graph
       CPU:  Unspecified  |   Platform:  Linux
Changes (by neteler):
 * milestone:  7.0.0 => 7.0.5
Comment:
 Replying to [comment:2 lazaa]:
 > From the documentation it seems that currently the module
 d.vect.thematic works only for polygons (type=area data). For point data
 there is a module in AddOns d.vect.thematic2. I tried run the module
 d.vect.thematic2 with a sample of points and everything worked well with
 no error.
 Interesting! The manual even says: "d.vect.thematic2 creates thematic maps
 from vector features of
 '''all types''' and numeric attributes stored in the attribute table
 connected to a vector
 map." (emphasis is mine).
 Perhaps time to merge into trunk and enhance/replace d.vect.thematic?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2494#comment:3>
