[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Helmut Kudrnovsky hellik at web.de
Sun May 8 23:26:37 PDT 2016
For MS windows have a look here:
https://lists.osgeo.org/pipermail/grass-dev/2016-May/080159.html
https://lists.osgeo.org/pipermail/grass-dev/2016-May/080160.html
>I assume win10 is too new so I tried win 7 and win8.1 using different
>computers. I
AFAIK the Windows version doesn't matter.
>Errors in:
>/usr/src/grass_trunk/raster/r.in.lidar
>/usr/src/grass_trunk/raster3d/r3.in.lidar
>/usr/src/grass_trunk/vector/v.out.lidar
>/usr/src/grass_trunk/vector/v.in.lidar
please check if the development dependencies for the lidar tools are present
in your build development.
install them or disable to build them (maybe the latter is better in Windows
64bit as there may be some issues with the las tools in OSGeo4W 64bit
AFAIR).
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Seeking-advices-for-image-segmentation-algorithms-and-windows-compile-question-tp5264642p5265294.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
