[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Moritz Lennert
mlennert at club.worldonline.be
Mon May 9 00:40:06 PDT 2016
On 09/05/16 08:26, Helmut Kudrnovsky wrote:
> For MS windows have a look here:
> https://lists.osgeo.org/pipermail/grass-dev/2016-May/080159.html
> https://lists.osgeo.org/pipermail/grass-dev/2016-May/080160.html
>> I assume win10 is too new so I tried win 7 and win8.1 using different
>> computers. I
> AFAIK the Windows version doesn't matter.
>> Errors in:
>> /usr/src/grass_trunk/raster/r.in.lidar
>> /usr/src/grass_trunk/raster3d/r3.in.lidar
>> /usr/src/grass_trunk/vector/v.out.lidar
>> /usr/src/grass_trunk/vector/v.in.lidar
> please check if the development dependencies for the lidar tools are present
> in your build development.
> install them or disable to build them (maybe the latter is better in Windows
> 64bit as there may be some issues with the las tools in OSGeo4W 64bit
> AFAIR).
Yes, I agree: don't worry about Lidar at this stage. You should be able
to just ignore these errors and run GRASS anyhow. Have you tried running
it after this compile ?
Moritz
