[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Helmut Kudrnovsky hellik at web.de
Tue May 10 02:48:22 PDT 2016
>Ok, then you have to either solve the compilation errors (maybe you can
>send us the error.log of trying to run make in one of the directories
>which failed), or disable compilation by (I think - but am no expert in
>MS Windows compilation - Helmut, can you confirm ?) erasing the line
>--with-liblas=$PWD/mswindows/osgeo4w/liblas-config
>from ./mswindows/osgeo4w/package.sh.
it's the same as in linux, just comment out this line.
the las compiling may be related to a las-issue in OSGeo4W 64bit:
https://trac.osgeo.org/grass/ticket/2996
https://trac.osgeo.org/osgeo4w/ticket/493
so commenting out this line should/may help to compile, if the other
dependencies/requirements (wxpython, wxversion, dlls) are complete.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Seeking-advices-for-image-segmentation-algorithms-and-windows-compile-question-tp5264642p5265534.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
