[GRASS-dev] grass 7.2 planning
Vaclav Petras
wenzeslaus at gmail.com
Tue May 10 11:26:46 PDT 2016
On Tue, May 10, 2016 at 10:52 AM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> I'll create a ticket, so it is clear what's the plan.
Created ticket #3034 for the layers in v.in.lidar, removed the vector
output from r.in.lidar in r68418.
https://trac.osgeo.org/grass/ticket/3034
https://trac.osgeo.org/grass/changeset/68418
> I'll set it as a blocker, so it shows up together with the other blockers.
Here are the current blockers:
https://trac.osgeo.org/grass/query?priority=blocker&status=assigned&status=new&status=reopened&milestone=7.2.0&group=type&col=id&col=summary&col=priority&col=status&col=owner&col=component&col=version&order=priority
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160510/5789796d/attachment.html>
