[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Helmut Kudrnovsky hellik at web.de
Tue May 10 20:23:23 PDT 2016
Yang, Bo (yangb2) wrote
> Hi Helmut and Moritz,
>>error:
>>libintl-8.dell missing
>>libsystre-0.dll missing
>>ERROR: wxGUI requires wxPython. No module named wxversion
>>It looks like the running/buildenvironment is inkompetent.
>>all these dll's and wxpython should be available by the OSGeo4W
environment.
>>try the OSGeo4W advanced install to install all these missing libs and
wxpython
>>Regarding missing dll's and wxpython, try to install e.g. OSGeo4W-winGRASS
7.0.4, then all dependencies should be installed.
> I installed wxpython and OSGeo4W-winGRASS 7.0.4 via OSGeo4W, then build
> GRASS again (20min, no error reported). Now on my desktop there are both
> shortcuts of "GRASS GIS 7.1.svn" and "GRASS GIS 7.0.4".
> Currently the GRASS GIS 7.0.4 can be normally started without any issue.
> However, when start GRASS GIS 7.1.svn. the error below showed.
> I did some research on google. Given all the errors come from python, I am
> thinking probably there are conflicts come from multi-python installations
> of my computer (I have anaconda and ArcGIS installed on my computer, both
> have python 2.7). If you think so too I will find another computer to
> clean install a new win7/10 and try to start over the compile follow that
> tutorial.
> Best,
> Bo
> Appendix I: Error screenshot:
> Cleaning up temporary files...
> Starting GRASS GIS...
> Traceback (most recent call last):
>   File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\gis_set.py",
> line 1200, in
> <module>
>     GRASSStartUp = StartUp(0)
>   File
> "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
> line 7981, in __init__
>     self._BootstrapApp()
>   File
> line 7555, in _BootstrapApp
>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
> line 1175, in OnInit
>     StartUp = GRASSStartup()
> line 230, in __init__
>     self._set_properties(grassVersion, grassRevisionStr)
> line 282, in _set_properties
>     self.OnSetDatabase(None)
> line 929, in OnSetDatabase
>     self.UpdateLocations(self.gisdbase)
> line 796, in UpdateLocations
>     self.lblocations.InsertItems(self.listOfLocations, 0)
> line 1152, in InsertItems
>     self._LoadData(choices, disabled)
> line 1141, in _LoadData
>     index = self.InsertStringItem(sys.maxsize, item)
>   File
> "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_controls.py",
> line 4761, in InsertStringItem
>     return _controls_.ListCtrl_InsertStringItem(*args, **kwargs)
> wx._core.PyAssertionError: C++ assertion "m_count ==
> ListView_GetItemCount(GetHwnd())" failed at
> ..\..\src\msw\listctrl.cpp(1629) in wxListCtrl::InsertItem(): m_count
> should match ListView_GetItemCount
> ERROR: Error in GUI startup. See messages above (if any) and if necessary,
> please report this error to the GRASS developers.
> On systems with package manager, make sure you have the right GUI package,
> probably named grass-gui, installed.
> To run GRASS GIS in text mode use the -text flag.
> Exiting...
> Press any key to continue . . .
> Appendix II: file of error.log (usr/src/grass_trunk):
> GRASS GIS 7.1.svn r68375 compilation log
> Started compilation: Tue, May 10, 2016 10:46:44 PM
> Errors in:
> No errors detected.
> Finished compilation: Tue, May 10, 2016 10:48:16 PM
ok, good to know that it compiles now.
for the error message, see
https://trac.osgeo.org/grass/ticket/3011
I'll add your example to the ticket.
if you have another windows box without another python installation, try to
compile there until this ticket is solved.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Seeking-advices-for-image-segmentation-algorithms-and-windows-compile-question-tp5264642p5265678.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
