[GRASS-dev] [GRASS GIS] #2980: r.watershed and max_slope_length
trac at osgeo.org
Wed May 11 00:01:31 PDT 2016
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Docs | Version: 7.0.1
Resolution: | Keywords: r.watershed
CPU: OSX/Intel | Platform: MacOSX
Comment (by mmetz):
Replying to [ticket:2980 mankoff]:
> I'm not sure if this is a bug, but I think it might be. The
{{{max_slope_length}}} seems to have no effect in the {{{r.watershed}}}
program. Below is an example that should work on the NC data set. I'd
expect there to be different accumulation maps based on setting
{{{max_slope_length}}}, but they appear identical.
The `max_slope_length` option only affects RUSLE outputs `length_slope`
and `slope_steepness`. From the manual: "This input is used for the RUSLE
calculations".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2980#comment:3>
