[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
GRASS GIS trac at osgeo.org
Wed May 11 00:26:21 PDT 2016
  Reporter:  pieside  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.0.4
 Component:  Default  |    Version:  7.0.3
Resolution:           |   Keywords:  FreeBSD
       CPU:  x86-64   |   Platform:  Other Unix
Comment (by mmetz):
 Replying to [comment:3 glynn]:
 > Replying to [comment:2 pieside]:
 > > The problems seems to be an old friend:
 > /home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
 freebsd10.2/lib/libgrass_gis.7.0.3.so: undefined reference to `libiconv'
 > This usually means that it's including <iconv.h> from libiconv but
 linking against the system iconv (which may be part of libc).
 > One way to solve issues with multiple library versions is to create
 "include" and "lib" directories, populate them with symlinks to the
 desired versions of the headers and libraries, and use --with-includes=
 and --with-libs= to put those directories at the front of the search path.
 You can also configure GRASS, then manually edit
 include/Make/Platform.make and set
 ICONVLIB            =
 to
 ICONVLIB            = -liconv
 Most of GRASS then compiles for me on FreeBSD 10.3 with both clang and
 gcc, with the exception of wxnviz and the temporal modules (problem with
 numpy + ctypes), but that is a different problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:4>
