[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Markus Neteler
neteler at osgeo.org
Wed May 11 22:39:21 PDT 2016
On May 12, 2016 6:34 AM, "Yang, Bo (yangb2)" <yangb2 at mail.uc.edu> wrote:
> For the 32 bit version system the error:
> GRASS GIS 7.1.svn r68419 compilation log
> Started compilation: Wed, May 11, 2016 7:34:55 PM
> Errors in:
> /usr/src/grass_trunk/lib/python/ctypes
> /usr/src/grass_trunk/display/d.grid
> /usr/src/grass_trunk/display/d.path
> /usr/src/grass_trunk/temporal/t.vect.univar
> In case of errors please change into the directory with error and run
'make'.
... Did you try this?
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
Please try as suggested.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160512/f589a28e/attachment.html>
