[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Yang, Bo (yangb2)
yangb2 at mail.uc.edu
Thu May 12 18:44:09 PDT 2016
Hi Markus,
Thanks for the advice! I’ve tried change into the directory with error and run 'make'.
For the 32 bit version, error is appendix I; After I run ‘make’, the report is in appendix II.
Best,
Bo Yang
Appendix I:
GRASS GIS 7.1.svn r68419 compilation log
Started compilation: Wed, May 11, 2016 7:34:55 PM
Errors in:
/usr/src/grass_trunk/lib/python/ctypes
/usr/src/grass_trunk/display/d.grid
/usr/src/grass_trunk/display/d.path
/usr/src/grass_trunk/display/d.vect
/usr/src/grass_trunk/display/d.vect.chart
/usr/src/grass_trunk/display/d.vect.thematic
/usr/src/grass_trunk/display/d.where
/usr/src/grass_trunk/general/g.copy
/usr/src/grass_trunk/general/g.findfile
/usr/src/grass_trunk/general/g.list
/usr/src/grass_trunk/general/g.proj
/usr/src/grass_trunk/general/g.region
/usr/src/grass_trunk/general/g.remove
/usr/src/grass_trunk/general/g.rename
/usr/src/grass_trunk/raster/r.carve
/usr/src/grass_trunk/raster/r.contour
/usr/src/grass_trunk/raster/r.cost
/usr/src/grass_trunk/raster/r.drain
/usr/src/grass_trunk/raster/r.external
/usr/src/grass_trunk/raster/r.external.out
/usr/src/grass_trunk/raster/r.flow
/usr/src/grass_trunk/raster/r.horizon
/usr/src/grass_trunk/raster/r.in.gdal
/usr/src/grass_trunk/raster/r.in.lidar
/usr/src/grass_trunk/raster/r.latlong
/usr/src/grass_trunk/raster/r.out.gdal
/usr/src/grass_trunk/raster/r.proj
/usr/src/grass_trunk/raster/r.random
/usr/src/grass_trunk/raster/r.reclass
/usr/src/grass_trunk/raster/r.region
/usr/src/grass_trunk/raster/r.resamp.bspline
/usr/src/grass_trunk/raster/r.resamp.rst
/usr/src/grass_trunk/raster/r.sim/r.sim.water
/usr/src/grass_trunk/raster/r.sim/r.sim.sediment
/usr/src/grass_trunk/raster/r.stream.extract
/usr/src/grass_trunk/raster/r.sun
/usr/src/grass_trunk/raster/r.sunhours
/usr/src/grass_trunk/raster/r.sunmask
/usr/src/grass_trunk/raster/r.to.vect
/usr/src/grass_trunk/raster/r.volume
/usr/src/grass_trunk/raster/r.walk
/usr/src/grass_trunk/raster/r.what
/usr/src/grass_trunk/raster3d/r3.flow
/usr/src/grass_trunk/raster3d/r3.in.lidar
/usr/src/grass_trunk/vector/v.buffer
/usr/src/grass_trunk/vector/v.build
/usr/src/grass_trunk/vector/v.build.polylines
/usr/src/grass_trunk/vector/v.category
/usr/src/grass_trunk/vector/v.class
/usr/src/grass_trunk/vector/v.clean
/usr/src/grass_trunk/vector/v.cluster
/usr/src/grass_trunk/vector/v.colors
/usr/src/grass_trunk/vector/v.colors.out
/usr/src/grass_trunk/vector/v.db.connect
/usr/src/grass_trunk/vector/v.db.select
/usr/src/grass_trunk/vector/v.decimate
/usr/src/grass_trunk/vector/v.delaunay
/usr/src/grass_trunk/vector/v.distance
/usr/src/grass_trunk/vector/v.drape
/usr/src/grass_trunk/vector/v.edit
/usr/src/grass_trunk/vector/v.extract
/usr/src/grass_trunk/vector/v.extrude
/usr/src/grass_trunk/vector/v.generalize
/usr/src/grass_trunk/vector/v.hull
/usr/src/grass_trunk/vector/v.info
/usr/src/grass_trunk/vector/v.in.ascii
/usr/src/grass_trunk/vector/v.in.db
/usr/src/grass_trunk/vector/v.in.dxf
/usr/src/grass_trunk/vector/v.in.region
/usr/src/grass_trunk/vector/v.kcv
/usr/src/grass_trunk/vector/v.kernel
/usr/src/grass_trunk/vector/v.label
/usr/src/grass_trunk/vector/v.lidar.correction
/usr/src/grass_trunk/vector/v.lidar.edgedetection
/usr/src/grass_trunk/vector/v.lidar.growing
/usr/src/grass_trunk/vector/v.lrs/v.lrs.create
/usr/src/grass_trunk/vector/v.lrs/v.lrs.segment
/usr/src/grass_trunk/vector/v.lrs/v.lrs.label
/usr/src/grass_trunk/vector/v.lrs/v.lrs.where
/usr/src/grass_trunk/vector/v.proj
/usr/src/grass_trunk/vector/v.mkgrid
/usr/src/grass_trunk/vector/v.neighbors
/usr/src/grass_trunk/vector/v.net
/usr/src/grass_trunk/vector/v.net.alloc
/usr/src/grass_trunk/vector/v.net.allpairs
/usr/src/grass_trunk/vector/v.net.bridge
/usr/src/grass_trunk/vector/v.net.centrality
/usr/src/grass_trunk/vector/v.net.components
/usr/src/grass_trunk/vector/v.net.connectivity
/usr/src/grass_trunk/vector/v.net.distance
/usr/src/grass_trunk/vector/v.net.flow
/usr/src/grass_trunk/vector/v.net.iso
/usr/src/grass_trunk/vector/v.net.path
/usr/src/grass_trunk/vector/v.net.salesman
/usr/src/grass_trunk/vector/v.net.spanningtree
/usr/src/grass_trunk/vector/v.net.steiner
/usr/src/grass_trunk/vector/v.net.timetable
/usr/src/grass_trunk/vector/v.net.visibility
/usr/src/grass_trunk/vector/v.normal
/usr/src/grass_trunk/vector/v.out.ascii
/usr/src/grass_trunk/vector/v.out.dxf
/usr/src/grass_trunk/vector/v.out.lidar
/usr/src/grass_trunk/vector/v.out.postgis
/usr/src/grass_trunk/vector/v.out.pov
/usr/src/grass_trunk/vector/v.out.svg
/usr/src/grass_trunk/vector/v.out.vtk
/usr/src/grass_trunk/vector/v.outlier
/usr/src/grass_trunk/vector/v.overlay
/usr/src/grass_trunk/vector/v.parallel
/usr/src/grass_trunk/vector/v.patch
/usr/src/grass_trunk/vector/v.perturb
/usr/src/grass_trunk/vector/v.split
/usr/src/grass_trunk/vector/v.qcount
/usr/src/grass_trunk/vector/v.random
/usr/src/grass_trunk/vector/v.reclass
/usr/src/grass_trunk/vector/v.rectify
/usr/src/grass_trunk/vector/v.sample
/usr/src/grass_trunk/vector/v.segment
/usr/src/grass_trunk/vector/v.select
/usr/src/grass_trunk/vector/v.support
/usr/src/grass_trunk/vector/v.surf.bspline
/usr/src/grass_trunk/vector/v.surf.idw
/usr/src/grass_trunk/vector/v.surf.rst
/usr/src/grass_trunk/vector/v.transform
/usr/src/grass_trunk/vector/v.to.3d
/usr/src/grass_trunk/vector/v.to.db
/usr/src/grass_trunk/vector/v.to.points
/usr/src/grass_trunk/vector/v.to.rast
/usr/src/grass_trunk/vector/v.to.rast3
/usr/src/grass_trunk/vector/v.type
/usr/src/grass_trunk/vector/v.univar
/usr/src/grass_trunk/vector/v.voronoi
/usr/src/grass_trunk/vector/v.what
/usr/src/grass_trunk/vector/v.what.rast
/usr/src/grass_trunk/vector/v.what.rast3
/usr/src/grass_trunk/vector/v.vect.stats
/usr/src/grass_trunk/vector/v.vol.rst
/usr/src/grass_trunk/vector/v.out.ogr
/usr/src/grass_trunk/vector/v.in.ogr
/usr/src/grass_trunk/vector/v.external
/usr/src/grass_trunk/vector/v.in.lidar
/usr/src/grass_trunk/vector/v.external.out
/usr/src/grass_trunk/misc/m.nviz.image
/usr/src/grass_trunk/misc/m.transform
/usr/src/grass_trunk/imagery/i.cca
/usr/src/grass_trunk/imagery/i.cluster
/usr/src/grass_trunk/imagery/i.gensig
/usr/src/grass_trunk/imagery/i.gensigset
/usr/src/grass_trunk/imagery/i.group
/usr/src/grass_trunk/imagery/i.maxlik
/usr/src/grass_trunk/imagery/i.ortho.photo/i.ortho.camera
/usr/src/grass_trunk/imagery/i.ortho.photo/i.ortho.elev
/usr/src/grass_trunk/imagery/i.ortho.photo/i.ortho.rectify
/usr/src/grass_trunk/imagery/i.rectify
/usr/src/grass_trunk/imagery/i.segment
/usr/src/grass_trunk/imagery/i.smap
/usr/src/grass_trunk/imagery/i.target
/usr/src/grass_trunk/imagery/i.pca
/usr/src/grass_trunk/ps/ps.map
/usr/src/grass_trunk/scripts/v.what.strds
/usr/src/grass_trunk/temporal/t.create
/usr/src/grass_trunk/temporal/t.support
/usr/src/grass_trunk/temporal/t.topology
/usr/src/grass_trunk/temporal/t.list
/usr/src/grass_trunk/temporal/t.info
/usr/src/grass_trunk/temporal/t.merge
/usr/src/grass_trunk/temporal/t.remove
/usr/src/grass_trunk/temporal/t.sample
/usr/src/grass_trunk/temporal/t.register
/usr/src/grass_trunk/temporal/t.unregister
/usr/src/grass_trunk/temporal/t.rast.accumulate
/usr/src/grass_trunk/temporal/t.rast.accdetect
/usr/src/grass_trunk/temporal/t.rast.aggregate
/usr/src/grass_trunk/temporal/t.rast.aggregate.ds
/usr/src/grass_trunk/temporal/t.rast.colors
/usr/src/grass_trunk/temporal/t.rast.contour
/usr/src/grass_trunk/temporal/t.rast.to.rast3
/usr/src/grass_trunk/temporal/t.rast.univar
/usr/src/grass_trunk/temporal/t.rast.list
/usr/src/grass_trunk/temporal/t.rast.mapcalc
/usr/src/grass_trunk/temporal/t.rast.algebra
/usr/src/grass_trunk/temporal/t.rast.neighbors
/usr/src/grass_trunk/temporal/t.rast.series
/usr/src/grass_trunk/temporal/t.rast.export
/usr/src/grass_trunk/temporal/t.rast.out.vtk
/usr/src/grass_trunk/temporal/t.rast.import
/usr/src/grass_trunk/temporal/t.rast.gapfill
/usr/src/grass_trunk/temporal/t.rast.extract
/usr/src/grass_trunk/temporal/t.rast.to.vect
/usr/src/grass_trunk/temporal/t.rast.what
/usr/src/grass_trunk/temporal/t.rast3d.list
/usr/src/grass_trunk/temporal/t.rast3d.extract
/usr/src/grass_trunk/temporal/t.rast3d.mapcalc
/usr/src/grass_trunk/temporal/t.rast3d.algebra
/usr/src/grass_trunk/temporal/t.rast3d.univar
/usr/src/grass_trunk/temporal/t.rename
/usr/src/grass_trunk/temporal/t.select
/usr/src/grass_trunk/temporal/t.snap
/usr/src/grass_trunk/temporal/t.shift
/usr/src/grass_trunk/temporal/t.vect.list
/usr/src/grass_trunk/temporal/t.vect.db.select
/usr/src/grass_trunk/temporal/t.vect.export
/usr/src/grass_trunk/temporal/t.vect.extract
/usr/src/grass_trunk/temporal/t.vect.algebra
/usr/src/grass_trunk/temporal/t.vect.import
/usr/src/grass_trunk/temporal/t.vect.what.strds
/usr/src/grass_trunk/temporal/t.vect.observe.strds
/usr/src/grass_trunk/temporal/t.vect.univar
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they appear in the error log. If you get an error building a library, you will also get errors from anything which uses the library.
Finished compilation: Wed, May 11, 2016 7:47:43 PM
Appendix II:
$ make
make /usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib
make[1]: Entering directory '/usr/src/grass_trunk/lib/python/ctypes'
make[1]: '/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib'
is up to date.
make[1]: Leaving directory '/usr/src/grass_trunk/lib/python/ctypes'
make OBJ.i386-w64-mingw32/date.py OBJ.i386-w64-mingw32/gis.py
OBJ.i386-w64-mingw32/raster.py OBJ.i386-w64-mingw32/gmath.py
OBJ.i386-w64-mingw32/proj.py OBJ.i386-w64-mingw32/imagery.py
OBJ.i386-w64-mingw32/vector.py OBJ.i386-w64-mingw32/rtree.py
OBJ.i386-w64-mingw32/display.py OBJ.i386-w64-mingw32/stats.py
OBJ.i386-w64-mingw32/dbmi.py OBJ.i386-w64-mingw32/raster3d.py
OBJ.i386-w64-mingw32/arraystats.py OBJ.i386-w64-mingw32/cluster.py
OBJ.i386-w64-mingw32/vedit.py OBJ.i386-w64-mingw32/ogsf.py
OBJ.i386-w64-mingw32/nviz.py OBJ.i386-w64-mingw32/segment.py
OBJ.i386-w64-mingw32/rowio.py OBJ.i386-w64-mingw32/temporal.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/date.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/gis.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/raster.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/gmath.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/proj.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/imagery.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/vector.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/rtree.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/display.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/stats.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/dbmi.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/raster3d.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/arraystats.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/cluster.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/vedit.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/ogsf.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/nviz.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/segment.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/rowio.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/temporal.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/__init__.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/ctypes_preamble.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/ctypes_loader.py
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/date.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/gis.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/raster.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/gmath.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/proj.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/imagery.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/vector.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/rtree.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/display.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/stats.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/dbmi.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/raster3d.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/arraystats.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/cluster.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/vedit.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/ogsf.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/nviz.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/segment.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/rowio.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/temporal.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/__init__.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/ctypes_preamble.pyc
/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python/grass/lib/ctypes_loader.pyc
make[1]: 'OBJ.i386-w64-mingw32/date.py' is up to date.
make[1]: 'OBJ.i386-w64-mingw32/gis.py' is up to date.
make[1]: 'OBJ.i386-w64-mingw32/raster.py' is up to date.
make[1]: 'OBJ.i386-w64-mingw32/gmath.py' is up to date.
GISRC=/usr/src/grass_trunk/dist.i386-w64-mingw32/demolocation/.grassrc71
GISBASE=C:/msys32/usr/src/grass_trunk/dist.i386-w64-mingw32
PATH="/usr/src/grass_trunk/dist.i386-w64-mingw32/bin:/usr/src/grass_trunk/dist.i386-w64-mingw32/bin:/usr/src/grass_trunk/dist.i386-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys32/usr/src/grass_trunk/dist.i386-w64-mingw32/etc/python;C:/msys32/usr/src/grass_trunk/dist.i386-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/usr/src/grass_trunk/dist.i386-w64-mingw32/bin:/usr/src/grass_trunk/dist.i386-w64-mingw32/bin:/usr/src/grass_trunk/dist.i386-w64-mingw32/scripts:/usr/src/grass_trunk/dist.i386-w64-mingw32/lib:/usr/src/grass_trunk/dist.i386-w64-mingw32/lib:/mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0"
LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/OSGeo4W/include
-D_FILE_OFFSET_BITS=64
-I/usr/src/grass_trunk/dist.i386-w64-mingw32/include
-D__GLIBC_HAVE_LONG_LONG" -lgrass_gproj.7.1.svn -I/c/OSGeo4W/include
/usr/src/grass_trunk/dist.i386-w64-mingw32/include/grass/gprojects.h
/usr/src/grass_trunk/dist.i386-w64-mingw32/include/grass/defs/gprojects.h
-o OBJ.i386-w64-mingw32/proj.py
Status: Preprocessing c:/users/hao2309/appdata/local/temp/tmp8qrwop.h
Status: gcc -E -I/c/OSGeo4W/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD -IC:/OSGeo4W/include
"-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t"
"-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1"
Error: gcc -E -I/c/OSGeo4W/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys32/mingw32/i686-w64-mingw32/include/_mingw.h:275:0,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys32/mingw32/i686-w64-mingw32/include/crtdefs.h:10,
C:/msys32/mingw32/i686-w64-mingw32/include/math.h:13,
C:/OSGeo4W/include/proj_api.h:33,
C:/msys32/usr/src/grass_trunk/dist.i386-w64-mingw32/include/grass/gprojects.h:21,
c:/users/hao2309/appdata/local/temp/tmp8qrwop.h:1:
C:/msys32/mingw32/i686-w64-mingw32/include/vadefs.h:35:2: error:
#error VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: ^
Status: Parsing c:/users/hao2309/appdata/local/temp/tmp8qrwop.h
Error: C:/msys32/mingw32/i686-w64-mingw32/include/malloc.h:144: Syntax
error at '{'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/malloc.h:149: Syntax
error at 'return'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/malloc.h:163: Syntax
error at '{'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/malloc.h:165: Syntax
error at 'if'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/malloc.h:177: Syntax
error at '}'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:144: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:150: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:156: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:161: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:170: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:176: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:182: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:188: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:381: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:382: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:383: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:393: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:394: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:395: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:529: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:538: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:543: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:545: Syntax
error at ';'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:567: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:577: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:581: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:585: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:592: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:594: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:598: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:602: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:729: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:730: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:731: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:757: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:758: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:787: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:789: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:799: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:804: Syntax
error at 'argp'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:811: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:813: Syntax
error at ';'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:821: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/stdio.h:835: Syntax
error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:27:
Syntax error at 'va_list'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:36:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:37:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:39:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:42:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:45:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:57:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:58:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:59:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:61:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:64:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:65:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:68:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:69:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:72:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:73:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:76:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:77:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:79:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:81:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:83:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:85:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:88:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:89:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:107:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:108:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:110:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:116:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:124:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:126:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:128:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:130:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:145:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:146:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:148:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:150:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:153:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:154:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:157:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:158:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:161:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:162:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:165:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:167:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:169:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/stdio_s.h:170:
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/string_s.h:63:
Syntax error at '{'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/sec_api/string_s.h:64:
Syntax error at ':'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/time.h:226: Syntax
error at '{'
error at ';'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/time.h:227: Syntax
error at '{'
error at ';'
Error: C:/msys32/mingw32/i686-w64-mingw32/include/time.h:228: Syntax
error at '{'
error at ';'
Status: Processing description list.
File "./ctypesgen.py", line 142, in <module>
ctypesgencore.processor.process(descriptions, options)
File "./ctypesgencore/processor/pipeline.py", line 58, in process
find_source_libraries(data, options)
File "./ctypesgencore/processor/operations.py", line 206, in
library = ctypesgencore.libraryloader.load_library(library_name)
File "./ctypesgencore/libraryloader.py", line 62, in load_library
return self.load(path)
File "./ctypesgencore/libraryloader.py", line 240, in load
return _WindowsLibrary(path)
File "./ctypesgencore/libraryloader.py", line 223, in __init__
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:/msys32/mingw32/lib/python2.7/ctypes/__init__.py", line 443,
in LoadLibrary
return self._dlltype(name)
File "C:/msys32/mingw32/lib/python2.7/ctypes/__init__.py", line 365,
in __init__
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 126] The specified module could not be found
Makefile:99: recipe for target 'OBJ.i386-w64-mingw32/proj.py' failed
make[1]: *** [OBJ.i386-w64-mingw32/proj.py] Error 1
Makefile:77: recipe for target 'default' failed
make: *** [default] Error 2
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: Thursday, May 12, 2016 1:39 AM
To: Yang, Bo (yangb2) <yangb2 at mail.uc.edu>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>; Moritz Lennert <mlennert at club.worldonline.be>; Markus Metz <markus.metz.giswork at gmail.com>; Helmut Kudrnovsky <hellik at web.de>
Subject: Re: [GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
On May 12, 2016 6:34 AM, "Yang, Bo (yangb2)" <yangb2 at mail.uc.edu<mailto:yangb2 at mail.uc.edu>> wrote:
> For the 32 bit version system the error:
> Errors in:
... Did you try this?
Please try as suggested.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160513/81514e52/attachment-0001.html>
