[GRASS-dev] [GRASS GIS] #1377: wingrass7 hotkey Ctrl+V an have unexpected behaviour from windows user point of view
GRASS GIS trac at osgeo.org
Thu May 12 20:08:00 PDT 2016
point of view
  Reporter:  MilenaN      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  closed
  Priority:  normal       |  Milestone:  7.0.5
 Component:  wxGUI        |    Version:  unspecified
Resolution:  fixed        |   Keywords:  hotkeys, wxgui
       CPU:  x86-64       |   Platform:  MSWindows 7
Changes (by wenzeslaus):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 It seems that `Ctrl+V` is not used like this anymore. It should be
 `Ctrl+Shift+V`:
 $ cd grass/source/code
 $ grep --exclude-dir={.svn,OBJ.*,locale,dist.*} -IrnEi "ctrl.shift.V"
 gui/wxpython/xml/wxgui_items.xml:175:    <shortcut>Ctrl+Shift+V</shortcut>
 gui/wxpython/docs/wxGUI.html:594:  <dt>Ctrl+Shift+V</dt>
 gui/wxpython/lmgr/toolbars.py:96:                _("Add vector map layer
 (Ctrl+Shift+V)")),
 $ grep --color=auto --exclude-dir={.svn,OBJ.*,locale,dist.*} -IrnEi
 "ctrl.V"
 gui/wxpython/xml/menudata_psmap.xml:71:   <shortcut>Ctrl+V</shortcut>
 Tested on Ubuntu, closing as fixed, reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1377#comment:2>
