[GRASS-dev] [GRASS GIS] #960: Some hotkeys disabled in 6.5 wxgui
trac at osgeo.org
Thu May 12 20:12:13 PDT 2016
Reporter: epatton | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: hotkeys, wxgui
CPU: x86-64 | Platform: Linux
Comment (by wenzeslaus):
Replying to [ticket:960 epatton]:
> In the Grass 6.5 wxpython gui, using Ctrl+E closes the wxgui down
nicely,
This is now done by `Ctrl+Q` in 7.0.
> but Ctrl+Q doesn't exit Grass completely, it performs the same function
as Ctrl+E; is it supposed to exit Grass, including exiting it from the
shell as well?
`Ctrl+Q` gives you now choice what you want to close (at least in trunk
(7.1)).
> both 6.5 and trunk have the 'add raster layer' and 'add vector layer'
button with hotkeys labelled Ctrl+R and Ctrl+V respectively, but these
hotkeys seem to be disabled.
Those are now work and are done by `Ctrl+Shift+R` and `Ctrl+Shift+V`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/960#comment:2>
