[GRASS-dev] wxGUI programmer's manual ?
Anna Petrášová kratochanna at gmail.com
Fri May 13 06:00:37 PDT 2016
On Fri, May 13, 2016 at 7:09 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 13/05/16 01:55, Vaclav Petras wrote:
>> Hi Moritz,
>> On Thu, May 12, 2016 at 3:26 AM, Moritz Lennert
>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>> wrote:
>>     Trying to understand how some of the code in the wxGUI works, I'm
>>     confronted with the absence of documentation of the wxGUI code.
>> Please, feel free to ask on mailing list if something is unclear.
>>     Yes, there are docstrings in the code, but what is lacking is a
>>     programmer's manual that describes the general logic and gives a
>>     more precise overview of what is done in the different files and
>>     classes.
>>     Is there anything like this out there ?
>> Yes:
>> cd grass/source/code
>> make sphinxdoc
> I'm getting:
> Encoding error:
> 'ascii' codec can't decode byte 0xc3 in position 36: ordinal not in
> range(128)
> The full traceback has been saved in /tmp/sphinx-err-Ioryqi.log, if you want
> to report the issue to the developers.
> Makefile:85: recipe for target 'wxguihtml' failed
> make[1]: *** [wxguihtml] Error 1
> make[1]: Leaving directory
> '/data/home/mlennert/SRC/GRASS/grass_trunk/gui/wxpython/docs/wxgui_sphinx'
> include/Make/Sphinx.make:32: recipe for target 'sphinxdoc' failed
> make: *** [sphinxdoc] Error 2
> And in the log file there is this:
> # Sphinx version: 1.3.6
> # Python version: 2.7.11+ (CPython)
> # Docutils version: 0.12 release
> # Jinja2 version: 2.8
> # Last messages:
> # Loaded extensions:
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/dist-packages/sphinx/cmdline.py", line 243, in
> main
>     opts.warningiserror, opts.tags, opts.verbosity, opts.jobs)
>   File "/usr/lib/python2.7/dist-packages/sphinx/application.py", line 128,
> in __init__
>     confoverrides or {}, self.tags)
>   File "/usr/lib/python2.7/dist-packages/sphinx/config.py", line 277, in
> __init__
>     execfile_(filename, config)
>   File "/usr/lib/python2.7/dist-packages/sphinx/util/pycompat.py", line 128,
> in execfile_
>     exec_(code, _globals)
>   File "/usr/lib/python2.7/dist-packages/six.py", line 699, in exec_
>     exec("""exec _code_ in _globs_, _locs_""")
>   File "<string>", line 1, in <module>
>   File "conf.py", line 45, in <module>
>     grass_version = core.version()['version']
>   File
> "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
> line 1519, in version
>     data = parse_command('g.version', flags='rge', errors='ignore')
>   File
> line 503, in parse_command
>     return parse(res, **parse_args)
>   File
> "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/script/utils.py",
> line 215, in parse_key_val
>     v = decode(kv[1].strip())
>   File
> line 160, in decode
>     return bytes.decode(enc) if enc else bytes.decode()
> UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 36:
> ordinal not in range(128)
could you please try running
g.version -rge
and in Python
parse_command('g.version', flags='rge')
>> There is also:
>> https://grasswiki.osgeo.org/wiki/WxGUI_Programming_Howto
>> which should be probably moved to Trac or the documentation itself.
> Right, didn't know about this. Thanks !
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
