[GRASS-dev] wxGUI programmer's manual ?
Moritz Lennert
mlennert at club.worldonline.be
Fri May 13 06:15:04 PDT 2016
On 13/05/16 15:00, Anna Petrášová wrote:
> On Fri, May 13, 2016 at 7:09 AM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 13/05/16 01:55, Vaclav Petras wrote:
>>> Hi Moritz,
>>> On Thu, May 12, 2016 at 3:26 AM, Moritz Lennert
>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>>> wrote:
>>> Trying to understand how some of the code in the wxGUI works, I'm
>>> confronted with the absence of documentation of the wxGUI code.
>>> Please, feel free to ask on mailing list if something is unclear.
>>> Yes, there are docstrings in the code, but what is lacking is a
>>> programmer's manual that describes the general logic and gives a
>>> more precise overview of what is done in the different files and
>>> classes.
>>> Is there anything like this out there ?
>>> Yes:
>>> cd grass/source/code
>>> make sphinxdoc
>> I'm getting:
>> Encoding error:
>> 'ascii' codec can't decode byte 0xc3 in position 36: ordinal not in
>> range(128)
>> The full traceback has been saved in /tmp/sphinx-err-Ioryqi.log, if you want
>> to report the issue to the developers.
>> Makefile:85: recipe for target 'wxguihtml' failed
>> make[1]: *** [wxguihtml] Error 1
>> make[1]: Leaving directory
>> '/data/home/mlennert/SRC/GRASS/grass_trunk/gui/wxpython/docs/wxgui_sphinx'
>> include/Make/Sphinx.make:32: recipe for target 'sphinxdoc' failed
>> make: *** [sphinxdoc] Error 2
>> And in the log file there is this:
>> # Sphinx version: 1.3.6
>> # Python version: 2.7.11+ (CPython)
>> # Docutils version: 0.12 release
>> # Jinja2 version: 2.8
>> # Last messages:
>> # Loaded extensions:
>> Traceback (most recent call last):
>> File "/usr/lib/python2.7/dist-packages/sphinx/cmdline.py", line 243, in
>> main
>> opts.warningiserror, opts.tags, opts.verbosity, opts.jobs)
>> File "/usr/lib/python2.7/dist-packages/sphinx/application.py", line 128,
>> in __init__
>> confoverrides or {}, self.tags)
>> File "/usr/lib/python2.7/dist-packages/sphinx/config.py", line 277, in
>> __init__
>> execfile_(filename, config)
>> File "/usr/lib/python2.7/dist-packages/sphinx/util/pycompat.py", line 128,
>> in execfile_
>> exec_(code, _globals)
>> File "/usr/lib/python2.7/dist-packages/six.py", line 699, in exec_
>> exec("""exec _code_ in _globs_, _locs_""")
>> File "<string>", line 1, in <module>
>> File "conf.py", line 45, in <module>
>> grass_version = core.version()['version']
>> File
>> "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
>> line 1519, in version
>> data = parse_command('g.version', flags='rge', errors='ignore')
>> File
>> line 503, in parse_command
>> return parse(res, **parse_args)
>> File
>> "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/script/utils.py",
>> line 215, in parse_key_val
>> v = decode(kv[1].strip())
>> File
>> line 160, in decode
>> return bytes.decode(enc) if enc else bytes.decode()
>> UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 36:
>> ordinal not in range(128)
> could you please try running
> g.version -rge
> and in Python
> parse_command('g.version', flags='rge')
GRASS 7.1.svn (LL_WGS84):/data/home/mlennert > g.version -rge
version=7.1.svn
date=2016
revision=r68425
build_date=2016-05-13
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=67275
libgis_date="2015-12-20 13:50:48 +0100 (dim 20 déc 2015) "
proj4=4.9.2
gdal=2.0.2
geos=3.5.0
sqlite=3.12.1
g.parse_command('g.version', flags='rge')
{u'build_platform': u'x86_64-pc-linux-gnu', u'build_date':
u'2016-05-13', u'proj4': u'4.9.2', u'geos': u'3.5.0', u'sqlite':
u'3.12.1', u'libgis_revision': u'67275', u'libgis_date': u'"2015-12-20
13:50:48 +0100 (dim 20 d\xe9c 2015) "', u'version': u'7.1.svn', u'date':
u'2016', u'build_off_t_size': u'8', u'gdal': u'2.0.2', u'revision':
u'r68425'}
Looks like it is the accent in 'déc' in the date...
Moritz
