[GRASS-dev] [GRASS GIS] #3030: v. generalize fails to generalize polygons in a random manner
trac at osgeo.org
Mon May 16 09:53:33 PDT 2016
Reporter: dido | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.0.5
Component: Vector | Version: 7.0.4
Resolution: wontfix | Keywords: v.generalize
CPU: x86-64 | Platform: MSWindows 7
Comment (by neteler):
Replying to [comment:12 dido]:
> Still this particular use-case needs a good explanation in the
v.generalize manual. I could not find any clue that the generalize
algorithm will simply stop and retain the boundary untouched IF any
topology damage occurs during processing. The good workarounds must also
find a way to the manual -- to slice-down the input adequately, then to
apply v.generalize and v.dissolve, or to apply multiple v.generalize steps
with increasing distance.
Please consider to write a few sentences for the manual page (post here,
I'll merge it in).
Thanks!
Ticket URL: <http://trac.osgeo.org/grass/ticket/3030#comment:14>
