[GRASS-dev] [GRASS GIS] #3030: v. generalize fails to generalize polygons in a random manner
GRASS GIS trac at osgeo.org
Tue May 17 13:24:22 PDT 2016
  Reporter:  dido     |      Owner:  grass-dev@…
      Type:  defect   |     Status:  closed
  Priority:  major    |  Milestone:  7.0.5
 Component:  Vector   |    Version:  7.0.4
Resolution:  wontfix  |   Keywords:  v.generalize
       CPU:  x86-64   |   Platform:  MSWindows 7
Comment (by mmetz):
 Replying to [comment:14 neteler]:
 > Replying to [comment:12 dido]:
 > > Still this particular use-case needs a good explanation in the
 v.generalize manual. I could not find any clue that the generalize
 algorithm will simply stop and retain the boundary untouched IF any
 topology damage occurs during processing. The good workarounds must also
 find a way to the manual -- to slice-down the input adequately, then to
 apply v.generalize and v.dissolve, or to apply multiple v.generalize steps
 with increasing distance.
 > Please consider to write a few sentences for the manual page (post here,
 I'll merge it in).
 I have updated the manual and changed the error output to contain errors
 in trunk r68451. The error output now allows to understand why a
 particular feature was not generalized.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3030#comment:15>
