[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Helmut Kudrnovsky
hellik at web.de
Thu May 19 00:14:39 PDT 2016
>3. I checked out codes from trunk and build it:
>svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
>PACKAGE_POSTFIX=-daily ./mswindows/osgeo4w/package.sh
>After built it reported:
>Started compilation: Thu May 19 00:45:39 EDT 2016
>Errors in:
>/usr/src/grass_trunk/raster/r.in.lidar
>/usr/src/grass_trunk/raster3d/r3.in.lidar
>/usr/src/grass_trunk/vector/v.out.lidar
>/usr/src/grass_trunk/vector/v.in.lidar
>In case of errors please change into the directory with error and run
'make'.
>If you get multiple errors, you need to deal with them in the order they
>appear in the error log. If you get an error building a library, you will
>also get errors from anything which uses the library.
as already mentioned in an earlier reply, please delete
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/package.sh#L178
i.e.
--with-liblas=$PWD/mswindows/osgeo4w/liblas-config \
from your local package.sh
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Seeking-advices-for-image-segmentation-algorithms-and-windows-compile-question-tp5264642p5267138.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
