[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Helmut Kudrnovsky hellik at web.de
Thu May 19 00:58:33 PDT 2016
>I searched that libgrass_btree2.7.1.svn.dll are located in folder of "
msys32\usr\src\grass_trunk\dist.i386-w64-mingw32\lib" but I don't know why
the program still can not find it. Then I tried to copy all files from
"..\lib" to "..\bin", then run 'i.segment --ui' again:
>Then the error is:
>" the program can't start because libgcc_s_dw2-1.dll is missing from your
computer. Try reinstalling the program to fix this problem."
>I searched again and found libgcc_s_dw2-1.dll are located in both "
C:\msys32\mingw32\bin " and " C:\OSGeo4W\bin ".
>PS: I tried to copy either of them to the folder of
"msys32\usr\src\grass_trunk\dist.i386-w64-mingw32\bin" but the i.segment
juse start and force closed.
>Given this missing dll error always reported, I am writing to ask if anyone
could help. Any suggestions would be greatly appreciated.
following
https://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallingGRASSGIS
"GRASS GIS should now be installed in c:\osgeo4w\apps\grass\grass-7.1.svn."
and
https://trac.osgeo.org/grass/wiki/CompileOnWindows#Usage
" To start GRASS use the icon on the desktop or if you want to be able to
use the command line from within GRASS.
Type in cmd console (assuming that we compiled GRASS 7.1):
c:\osgeo4w\bin\grass71svn.bat"
"cmd console" is the OSgeo4W cmd console.
you are looking in the build directory, the install directory, as mentioned
above, should be e.g.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Seeking-advices-for-image-segmentation-algorithms-and-windows-compile-question-tp5264642p5267155.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
