[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Helmut Kudrnovsky hellik at web.de
Sat May 21 02:35:46 PDT 2016
>'make' is not recognized as an internal or external command,
>operable program or batch file.
>Previously I run 'make' in mingw and it works, seems using OSgeo4w >cmd
can't run 'make'
make is part of the mingw32/64-installation, but not of the OSGeo4W stack.
if you are in the OSGeo4W console, you have to add your mingw32/64 to the
%PATH% that make can be found.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Seeking-advices-for-image-segmentation-algorithms-and-windows-compile-question-tp5264642p5267529.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
