[GRASS-dev] v.info layer option
Markus Metz
markus.metz.giswork at gmail.com
Thu May 26 14:21:19 PDT 2016
Hi Luca,
apparently [0] the layer option is only needed for v.info -c (Print
types/names of table columns for specified layer instead of info and
exit). What information about a vector do you want to get? Note that
vector objects (points, lines, boundaries, areas) are always present,
even if they are not linked to a layer at all. Maybe v.category
option=report is more appropriate for your needs?
A question like this should rather go to the user ml.
Markus M
[0] https://grass.osgeo.org/grass71/manuals/v.info.html
On Thu, May 26, 2016 at 4:06 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi devs,
> I tried v.info using layer option but I cannot see any differences, I
> notice also that is possible to use any character and it doesn't
> return any error, you could also set layer=a and it return the same
> value.
> Do you have the same behavior?
> ciao
> Luca
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
